RCX
Andy
Montreal
2017 Type R | Sentra SER | GMC Terrain.
Inner clearance will be limited to around 9.5 ~50-55, before it is far too close to the inside. 11" likely would not work.
Do you mean there is 5-10mm of clearance inside? 50-55 offset pushes wheel out 5-10mm.
On my FK8 I ran 255/40R18 on 9.5x18 +50 Weds.
11th Gen Honda Civic Official Wheel Fitment Thread for 11th Gen FL5 Civic Type R 1702909773971
" Compared to your existing wheel, this new wheel will have an inner rim which is 3.6mm further away from the suspension strut. The outer rim will poke out 16.4mm more than before. "
Thinking of buying 10 or 10.5x19 for DE5.
11th Gen Honda Civic Official Wheel Fitment Thread for 11th Gen FL5 Civic Type R 1702911275955
" Compared to your existing wheel, this new wheel will have an inner rim which is 3.7mm closer to the suspension strut. The outer rim will poke out 21.7mm more than before. "
Dont think 10x19 +50-55 would have any issues at all.
Valeriafk8
Mark
Bayonne, NJ
Fk8
On a stock height would I rub if I get a 265/40/18 on a +45 offset wheels with 3 passengers?
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
Black (CBP) FK8 Civic Type R,
It would not rub
wolo
Hi, I'm looking at ENKEI T6R 18x9.5 +45 and Blizzak LM005 255/40R18. Wondering if you see any fitment issues like rubbing? Tirerack says it's an aggressive fitment and might require fender mods. Thanks in advance.
You'll be fine with those wheels and tires. A bunch of guys are running more aggressive setups than that with no issue.
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
TE37SL 18x9.5 +45 5x120 Mag Blue x FL5 Civic Type R!
11th Gen Honda Civic Official Wheel Fitment Thread for 11th Gen FL5 Civic Type R IMG_9586
11th Gen Honda Civic Official Wheel Fitment Thread for 11th Gen FL5 Civic Type R IMG_9584 2
Negitoro7
Winter beater currently
I see that TE37 Saga S-Plus are now available in 19x9.5, and +55 is an option. What are the pros and cons of going with et55 instead of more aggressive et45 besides looks?
Considering the more conservative offset to stay closer to stock geometry. Will the +55 have a significant advantage in terms of suspension wear and tear over time? Which offset will look less “awkward” if I decide to stay with stock ride height (but might go Spoon springs eventually)?
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
You will get less torque-steer at a +55 compared to a +45; but aside from that it is just visual. Both will look good; a +45 would look less awkward in our opinion. There will not be considerable wear-and-tear on suspension and tire regardless of the offset you choose.
Gotama
Colorado
2024 SGP FL5
I’ve been eyeing the 57DR on your site but I feel that I would regret the offset. Is there a reason why they went with +38 instead of something over +40? I want to wrap it with 275/35r18 and lower it with Swift or Spoon springs.
Should I risk it with that wheel or save up more money to get CE28 or TE37 with a +4X offset?
Noize
Under the radar
Hey Thomson!
What all do you guys have available in 19” right now?
Sometimes a few options for Gram Lights aren’t on the site.
惹Raizzelle
Raizzelle
BC, Canada
2024 Honda Civic FL5 Type R
I was just about to ask the exact same question as I’m looking at the same wheel, spec of +38, and tire spec you are planning to. LOL
up for this question ?? following
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
Hey Thomson!
Plenty of options; Gramlights 57DR/57CR/TE37 Ultra/BBS - a few more as well. Send me a Pm and we can talk!
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
PM me!
