Status
Not open for further replies.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL FL5 Wing Delete: Clean Looks, Smart Engineering 1763678075349-u2
We've seen countless posts from FL5 Type R owners removing their wings, only to uncover an unsightly, rough-cut opening in the plastic hatch. Finally, FL5 owners have a clean, reversible solution that lets them run a wingless look without leaving exposed holes or swapping to a different hatch.
We are genuinely excited about this product because the FL5 looks fantastic without the wing. The PRL Wing Delete offers a cost-effective, easy, and fully reversible way to dramatically transform the appearance of your car. Its sleek form is designed to follow the body lines of the FL5 and visually tie into the shark-fin antenna on the roof. Before landing on this final design, we tested countless 3D-printed prototypes with varying upper-surface shapes, including simple flat plates, until we found the balance of form and function we wanted.
Why Isn’t It Flush?
We know the biggest question we'll get is obvious: “Why Didn't You Make It flush?” There are a couple of very straightforward reasons why a flush-fitting design would actually be worse.
1. The Factory Hole Is Not Precise
Figure 1 shows the hole in the hatch that accepts the wing risers. This slotted opening is cut into the plastic by a router after molding, and the result is:
  • a rough, uneven cut
  • burrs and sharp edges
  • non-precision placement
11th Gen Honda Civic PRL FL5 Wing Delete: Clean Looks, Smart Engineering Wing-Delete-1
The sheet metal opening underneath is smaller, and the wing riser base is designed to cover the variability in size and location. The slack is taken up by a foam seal and the footprint of the riser.
If we made a flush delete plate, it would have to be undersized to avoid contacting the rough plastic edges. That would create a noticeable gap around the outside of the plate while also exposing the ugly cut underneath. There is no clean way to make a flush design that accounts for this inconsistent geometry.
2. A Flush Plate Would Create Water-Ingress and Corrosion Risks
Both the OEM risers and our wing delete use a closed-cell foam seal that compresses between the hatch and the base of the riser. This is a proven sealing method that works with the thickness and variability of the factory plastic.
A flush-fitting plate would require a completely different sealing method, and any alternative would need to seal against the sheet metal, not the plastic, due to the thin outer skin and variability of the hole size.
While sealing directly to the metal could stop water from entering the cabin immediately, it would allow water to pool between the metal and the outer plastic skin. That trapped moisture would eventually:
  • accelerate corrosion
  • compromise the hatch structure
  • likely lead to water finding its way into the cabin over time
11th Gen Honda Civic PRL FL5 Wing Delete: Clean Looks, Smart Engineering Wing-Delete-2
11th Gen Honda Civic PRL FL5 Wing Delete: Clean Looks, Smart Engineering Wing-Delete-3
Simply put, it would introduce avoidable long-term problems.
The Bottom Line
A flush-fit design would be objectively worse for two major reasons:
  1. It would require an undersized plate, creating a visible gap and exposing the rough factory opening.
  2. It would introduce water intrusion and corrosion risk by exposing inner sheet metal and relying on an inferior sealing method.
For these reasons, the PRL Wing Delete uses the same proven sealing approach as both the factory wing risers and our PRL risers. This method ensures proper fitment, avoids structural risks, and allows us to incorporate clean, attractive styling on the visible surface of the plate. It is the cleanest, safest, and most reliable way to run a wingless FL5. With this design, you get the look you want without compromising the integrity of your hatch or the longevity of your car.
caraholic
SC
Taycan Turbo S, JL 392XR, 981S, F430, FL5 CTR
Any more pictures and does it come with the lip spoiler?
QuickR
Steve
Will you offer paint matched options?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
We don't plan to offer paint matched options. OEM paint is extremely difficult to match, which is why our P0-7F wheels are not offered in championship white no matter how much we wanted to do it. We decided to go with an anodized finish. This way, they are protected from corrosion if you want to install them as is, but also ready for a body shop to prime & paint if anybody would like to go that route.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
chopsuey34
West Michigan
Looks like a wide body Civic hatch 🤷‍♂️
Zeke01
Northern California
Civic CTR
Agree. Something like the HKS ducktail to finish the back end at minimum, that little middle lip if anything calls attention to the weak shape, especially at the three quarter view.
jcfishel
Cary, NC
2025 Honda Civic Type R #35339
Thank you very much for making these! You got a ETA on price and availability?
Status
