*The FL5 Track Junkie Thread*
chadwicke619
I have three brake related questions since we are on the topic.
1. What is the advantage of a big brake kit on the CTR? Stopping power? Heat management?
2. If I bought brake fluid like a year ago and it’s still completely sealed, is it good to go?
3. I have been using G Four 335 the entire time I’ve been tracking but I’ve never heard of anyone else really using it. As I’m starting to get faster, do I need even better?
1- All of them, definitely stopping power, way better heat management, weight savings (minimal but should be there), much better system to swap pads
2- Should be fine
3- Had to search that that was, its from project mu so should be good stuff
The new ones I just bought are flow formed or whatever. 21 lbs.
Had a few sets, the flow formed apex are excellent. yeah forged are technically lighter and stronger but only thing most are gaining is talking about having forged wheels lol
svvitch
? Exactly. I hate worrying about them covered in brake dust. It's dumb it's a dang wheel. So problem solved
BigBird
1. Most of the benefit is thermal capacity, but should decrease stopping distances a little as well as you'll also have increased pad and rotor size
2. yes
3. It's not readily available at most places, so SRF is probably the default that most track folks end up with, but from what I read, G Four 335 is very good, but probably want something with a higher dry boiling point on this platform.
Here is a great article on
Brake Fade/Fluids: https://grassrootsmotorsports.com/articles/how-to-fix-brake-fade/
Essex AP racing has a BF sale. Which kit was savagegeese running?
do we know what the difference is btw all the kits? Some are just the size of rotors 355 vs 372 but what about the other differences?
The paragons still a lot cheaper and are probably also very good, AP is the golden standard though.
I have been reading about melting boots on the oem brembos, definitely a thing, titanium shims are definitely a must. Also feel like it will depend on the pads, some pad material will transmit a lot more heat to the pistons than others.
Currently using EBC SR11 which are sintered and apparently will put a lot more heat on the caliper, I guess time will tell
svvitch
I think pad thickness. 18mm or 25 or 27mm pad thickness? Not sure of other differences. Even at BF prices I won't be doing this for a while ?
I will need to actually melt a set of boots and then I will upgrade but would likely just do paragon, this is too rich for me. But ngl, I have wanted a set when I had the M2 and still do now.
svvitch
I think it's like the forged wheels analogy ? I need to watch some videos on inspecting the boots of the brembos. I would hate to miss something and ruin a weekend.
BigBird
The calipers on the Type R has been around since 2004 on various applications. They do sell a high temp boot, but haven't researched enough on which one fits.
I would go with the bigger rotor, but very dependent on what wheel will fit.
BigBird
Ruined dust boots won't stop a weekend. There is a seal on the piston that stops fluid from coming out
svvitch
That's what I think I meant. I would hate to miss a seal but I don't think I would miss fluid leak lol.
