Waste Gate Rattle Noise
UCF120
Jon
Orlando,FL
So I actually don’t hear that wastegate rattle sound on my car..yet lol…one noise I hear on the OP’s video is a noticeable buzzing as he accelerates. The buzzing then goes away the second he lets off the gas. Immediately comes back as soon as he’s back on throttle.
ive heard this buzzing driving my car also and couldn’t figure out what it was until his video! Is that buzzing the fuel injectors?!? It sounds like it in the video and that’s crazy lol I’ve had numerous DI cars in the past and you can always hear a noticeably louder ticking at idle but never heard the rapid buzzing sound while driving…can anyone confirm that buzzing sound on throttle is the injectors? Would just clear up this sound for me
optronix
Mid-Atlantic
2026 Audi RS3, 2023 Macan GTS, 2025 Miata Club BBR
Yeah the valvetrain is extra noisy in this video because the microphone is right next to the valve cover. The noise is accentuated heavily in the video but essentially all the noise you're hearing that isn't the wastegate noise is the valvetrain.
Some cars just have noisy valvetrains; the K20C1 is pretty bad but I've heard worse. Porsche engines are insanely noisy, for example... the 2.5L turbo flat 4 in the 718 for example sounds like sewing machine at idle.
UCF120
Jon
Orlando,FL
appreciate it! Is that buzzing I’m referring to specially the fuel injectors or just valve train sound in general?
optronix
Mid-Atlantic
My guess is a little bit of everything. Injectors have a distinctive "tick" sound, but the rest of the valvetrain is just a conglomeration of rotating metal pieces effectively crashing into each other constantly at high speed with just a thin layer of oil to separate them...
Since the mic in the video is directly in the engine bay, it sounds egregious lol. I should note that your car should definitely not sound like that from inside the cabin. If it does, immediately check your oil level and/or get it to the dealer?! Only a small fraction of that rattling/ticking/buzzing should make its way into the cabin. But especially in situations like pulling into your garage with the windows down, it becomes especially noticeable.
When my car would make this wastegate noise, I could feel it in the pedal and even moderately loud music couldn't drown it out. I swear it's gotten much better.
UCF120
Jon
Orlando,FL
alright cool. Yeah car definitely does not sound like that inside the cabin. I can just hear that audible buzzing if I don’t have any music on and it was interesting. Even with music at a low volume it’ll down out that sound so it’s not concerning to me.
fredzy
PA
Sienna, GR86, TourX
Ha, I totally know the buzz you’re talking about. I noticed that early on. Buzz is the only way to describe it. It’s only annoying because it sounds like a sound a turd car would make haha. Pretty sure it’s just the injectors. Usually that’s only noticeable around idle, not low-mid speed like that.
mmm def
Dave
Nj
24 FL5, 09 NC2, 12 GE8
I have this same buzzing, especially noticeable on the gas going slow 1st 2nd and 3rd gear. I get the rattle on decel too but this one is while i give it light throttle. Thought my car was broken-guess it just needs an exhaust.
cryptolime
Wilmington, NC
i only really noticed the ringing/key jingle noise when decelerating at low speeds with the window down. Now i can hear another rattle/grind at 75-90% throttle a little over 3k rpms on my Si. I think it's just the wastegate...hopefully
I've only heard it once, and that was after swapping turbos. It did in on initial startup, but hasn't done it since.
MainMind
MainMind
Spain
FL5, Honda e
Can you check if the noise is more pronounced in "comfort" mode? With relaxed driving... in "Flanders" mode, after several miles, +R mode, on a hot day (almost 40°C), the noise hasn't reappeared...
lightningteg
Chris
Indiana, USA
98' DC4, 07' FA5, 25' FL5
Just my thoughts, but when you're trying to mechanically manipulate something that's super red hot metal, you don't have a lot of choice of connection methods from the actuator to the wastegate. Any kind of rubber or plastic that would normally provide a soft and quiet mechanical connection is out, it would burn up at those temps. You end up with a metal on metal connection that needs some play or else there's too much friction. The parts end up being intentionally loose and can vibrate.
The spring idea is a good one but it would increase the wear of the connection since you're putting pressure on it.
The noise is from the tolerance between the pin and hole of the linkage. Putting some tension on that to hold one side of the pin to one side of the hole seems like a logical thing. Unless you got a super heavy spring on there I doubt it would do anything. But needs to be more than that bic pen spring looking thing lol
cryptolime
Wilmington, NC
i think most electronic wastegates have a little rattle. i don't even notice mine anymore. sometimes i can hear a bit of a buzz when i'm right at 0 PSI boost. Wastegate is probably fluttering a bit since it's right between open and closed.
cryptolime
Wilmington, NC
160 miles in... heard the rattle coming home last night. :banghead:
mine is so faint that it doesn't bother me anymore. I mean, i can barely hear it unless I'm rolling slow, music off, and windows down. Just sounds like some keys jingling a bit. Only reason I was concerned in the first place, was because I was concerned there was something wrong.
how loud is yours?
I♥️LCY
Inland Empire
2026 Honda Civic Type R
It's faint. I can hear it music off, low speeds. I find it bothersome. I like to hear the natuarl sounds of an engine from time to time. That jingle will take some getting use to.
