Went just like I expected, the type S will always beat the type R in a straight line if its long enough. Has a bit more power and does not have a wing dragging down the car.
Integra23
2023 Integra 6spd A-Spec
I wish they did the pedal dance. It would help a bunch off the line fully disabling traction control like the FL5 allows.115 mph trap speed was impressive and shows that the teggy is held back by the launch.
well to be fair the 115 trap was after the turn so launch plays less of a factor and driver skill comes into play. But still both are very good.
Samurai1225
Chris
Cincinnati
For what it is worth the FL5 still holds the best U-Drag time over the ITS.
NoelPR
Somewhere in the SW
24' Integra Type S
Would interesting if both were with the same tires.
We know how good the ITS did with PS4 but everyone wonders if it will do better with Cup2s.
These comparisons are fun, but I think the Lightning Lap will be a better measure of how closely matched these cars are. I hope C&D includes the DE5 (shod in Michelin Pilot Sport Cup 2s) in their testing for 2024.
Some cars ran an R-comp on the testing C&D did for 2023. I'm keen to see how well the FL5 would perform with the Sport Cup 2 R. Perhaps you run into diminishing returns at that point, but would be interested to know nonetheless.
Integra23
Without both on same tires and Traction control disabled this test is pointless. Also we know there the same car with slightly different tune. I just wish the TLX race turned out better.
jtrader
James
OH
Not the most impressive numbers. Think I'll save the $50k (!) and keep my tuned civic, which is probably just as much fun on the streets as these overpriced bros. Cheers!
It’s funny the way he worded it, but if one doesn’t care about a lot of the exclusive stuff the CTR / ITS have (which definitely add to their cost), I can see a tuned Si being just as fun on the street…and I love seeing people’s Si builds. Cheers! ?
jtrader
James
OH
IDK what kind of numbers you expect from a 300HP FWD overpriced Civic lol
I guess I was referring to the 1/4 mile times that they got in the 14.6-14.7 range. I would've expected 13's especially with those trap speeds, which were impressive. Even w/ the lowly Elantra N, they were able to run a 14.2. Does not compute.
1. 8 spd dual clutch automatic trans
2. Launch control
NoelPR
Somewhere in the SW
24' Integra Type S
2. Launch control
You missed #3
Unprepared surface
Those elantra N DCT had posted high 12s stock in the quartermile when everything was
in their favor (DA, octane learning, etc)
It computes you are just too inexperienced to see it. :thumbsup:
Look reasons above, especially # 3.
@NoelPR Unprep’d surface applies to all the race times that Edmunds has recorded. You should do your due diligence and understand the full data before jabbing someone for being “inexperienced.”?
@jtrader didn’t understand why the EN was a little faster on the same track under the same conditions as the CTR / ITS. Automatic trans + launch control is the answer to that.
