Robo7
So after looking through 100 samples of different shades of white for powder coating, I think these 2 are the closest. Number one is called off-white-II and number two is called snow bunny. Company is prismatic powders.
I am planning on trying something on a set of wheels with off white II but likely not till March or April.
Also, three looked close but then I put it with the other two and it was much too light so I didn’t really think it would work.
Reviving this old post. I ordered some powder coat swatches as well. Indeed the closest are called "Snow Bunny" and "Off White II" from Prismatic Powders. "Snow Bunny" is a satin finish though so while out of direct sunlight it looks really close, in the sunlight the gloss of the car's paint becomes a different shade while "Snow Bunny" stays the same and it looks quite different. "Off White II" is a gloss finish, but it still isn't as glossy as the car. It's the color I would try if I had to go with one, but it's still going to look slightly off in certain lighting conditions. The only way to get a true color match is to go with paint or you could try adding some type of gloss finish over "Off White II" to get it closer to the gloss level of the car. Interestingly, some other colors their website says are a copy of Championship White are not even close. Anyway hope that helps someone.
scottjua
Scott
Plano, TX
Advan GT Beyond 19x9.5 +45
Falken Azenis RT660 275-30-19
Muteki Hub Centric Ring Set 72.6mm / 64.1mm
Lowered 1” front/back on Swift Springs
11 more photos…
11 more photos…
For those of us without facebook… can you please post all the pics?
minimedic
2025 Honda Civic Type R - SGP
This is my 2025 Honda Civic Type R
Wheels & Tires:
Spoon Sports SW388 / 18" x 10" +40
Yokohama Advan 265/35/18
Suspension:
Spoon Sports Lowering Springs
How is fitment? any rubbing and how much poke. I thinking about running a 18x9.5 +35 which has a very similar wheel poke to your setup (1mm different).
00057
SATX
It is 100% perfect fitment.
Doesn't stick out at all and now that its totally settled in I love it
Rons_FL5
Ron
2025 Civic Type R, 2022 Tesla Model Y, 2006 Evo 9
Hi all,
I am running TE37 SL 19x9.5 +36 on stock tires (265/30/19). Stock height. Doesn’t rub at all.
I’m thinking of running Eibach pro kit lowering springs. Has anyone run this set up lowered? If so, what is your experience (rubbing, camber needed, etc)?
11th Gen Honda Civic Official Wheel Fitment Thread for 11th Gen FL5 Civic Type R IMG_2828
System Motorsports
System Motorsports
Thomson
Thomson
Hayward
Black (CBP) FK8 Civic Type R,
Allthingsfl5
indiana
2025 CW FL5
Anyone running CE28N+ 18x9.5 I found that the center cap size outer diameter is about 65mm and the inner diameter about 63mm to clip in. These fit perfect and I’m very happy with how they look. So much cleaner looking. Nothing worse than nice wheels with rusty brake rotors in the middle
4pcs Car Wheel Hubcaps Wheel... https://www.amazon.com/dp/B0F142D6WP?ref=ppx_pop_mob_ap_share
These still holding up? Just got these same wheels.
Just installed my Eibach Pro Kit springs. Came out nicer than I expected. No rubbing with this aggressive offset too! Love it!
wheels: TE37 SL Black Editions, 19x9.5 +36, stock tires.
That's cute and all but I think we're all here for the dog :love:. We've seen enough FL5s
