🚀 TRUSTALIGN - Time Attack FL5 Build Journal
tezzasaurusrex
tezzasaurusrex
Terence
Would like to get some feedback on how this performs over oem dif. Also is it a hard installation how much time went into it.
Not too bad in terms of installation, just be careful with the reverse gear stack as I had accidentally flipped the reverse gear select sleeve over which stopped the gear housing from meeting the clutch housing properly. Took a while to figure out that this was the cause.
tezzasaurusrex
tezzasaurusrex
Terence
Full Race HPFP ✅
AEM LPFP ✅
Hondata 1530cc Injectors (bought the whole fuel system just to get these injectors ☠) ✅
Hondata Can Flex ✅
Injector Dynamics in-line fuel filter (still trying to figure out the plumbing/mounting location of the filter) ✅
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250808_192327
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250808_183937
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250808_180833
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250808_225520
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250704_150627
tezzasaurusrex
tezzasaurusrex
Terence
tezzasaurusrex
tezzasaurusrex
Terence
• Fabbed up a bracket to hold my intake pipe to the body, it's one of those types that go under the hose clamps of the silicone joiner. The ones commercially available are cheese (last one broke).
• Increased spring rates going on to deal with the extra load from the new aero package.
• Race car shiz
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250817_211043
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250818_165533
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250820_120226
Mrjustin81
MHI in ✅
Main coolant pipe heat wrapped ✅
You were running the kuro+, is that what I read somewhere in this thread?
Why did you switch? How do the two compare?
tezzasaurusrex
tezzasaurusrex
Terence
Nope, ran OEM and now upgraded to MHI
tezzasaurusrex
tezzasaurusrex
Terence
Mounting up some craft square replica mirrors, 3D scanning the door to design a mounting plate. Also reverse engineering the BSM system and relocating the warning light into the door so it still works with the new mirrors.
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250826_203733
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250828_174113
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250826_201701
tezzasaurusrex
tezzasaurusrex
Terence
Hardrace pillow ball rear B arm upright bushing fitted in place of the OE rubber one ✅
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250820_163236
Project Mu type PS rear pads + Paragon 2 PC discs fitted.
May be worth noting that the hat is 1.5mm thicker than the OE disc. This will result in the wheel sitting 1.5mm further out (effecting a decrease in wheel offset) ✅
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250827_103554
Aligned by yours truly
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250903_113649
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250903_113638
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250903_143531
Craft Square replica mirrors mounted up
Side Indicator functional
Blind Spot monitor system functional (relocated on the inside of door)
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250902_222244
TRUSTALIGN schedule J cage in
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250830_180605
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250831_183841
BSM relocation
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250830_122042
Sound Deadening removed - Honda didn't put much in
Only 2kg saved
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250830_114923
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250830_121455
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250830_114830
Tuned to 480hp at the hubs
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250822_210841
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250822_152404
DIY Seat delete panel
11th Gen Honda Civic 🚀 TRUSTALIGN - Time Attack FL5 Build Journal 20250831_183431
• Race car shiz
*Slaps oil filter...That ain't goin' nowhere.
Now it's safe!
