How far could the Fullrace HPFP and 2000cc injectors get you with full e85?
This is not a simple question but you would have enough fuel for over 500whp while running full e85.
Gambit
Tony
@Hondata can you confirm what size specification this thread is as I want to connect up a PTFE braided e85 hose with correct direct fitting to it.
11th Gen Honda Civic Hondata releases CANFlex for FL5 Civic Type R IMG_9727
BuntaTypeR
How much estimated power can this add with flex fuel?
Full-Race Civic Type R High-Pressure Fuel Pump $1999 (can i run flex fuel.withot.this?)
Hondata Fuel System Upgrade for 2017+ Honda Civic Type R FK8 / FL5 / DE5 $2500
I currently have prl intercooler, prl hvi, inlet pipe, charge pipe, front pipe and downpipe with stock exhaust.
So the flex fuel allows you to target more aggressive timing with the car due to the higher octane. So there is quite a bit more power to be had. With an upgraded fuel system 400whp is doable safely.
Tougefl5
You can run the hondata flex fuel kit on stock car. They did and post the data between stock and upgraded fuel system.
You can absolutely bolt on a go. But dialing it in to get everything optimized yields really good results.
svvitch
I'm bone stock except for hondata and the flex fuel kit. Getting tuned now will post some results once it's done ?
You know there is no such thing as optimized being a car guy lol
Optimized tune wise absolutely possible!
Optimized parts wise impossible and there will always be some itch. You will probably have an easier time finding a Unicorn.?
