Integra Type S Exhaust Swappable?
STEye
'23 CW CTR FL5
Anyone know if the ITS exhaust is a direct swap? Just curious.
HRace
United States
Honda Civic
If there are any more details on how many cuts were needed or if the exhaust hangers lined up, that would be appreciated. Sounds interesting.
JDM_DOHC_SiR
Uncle Dave
Chula Vista
Yes it’s 100% doable…. All the hangers line up perfectly the exhaust tips need to be shortened 5” but the nice part is Honda welded the tips on exhaust where it needs to be cut :thumbsup: also another nice benefit of the Type-S exhaust is the the internal Diameter of the muffler piping is larger than the CTR’s by 3-5mm:coffee:.. I would highly suggest that you get a good welder to tackle this and not some hack at a local exhaust shop:wave:
If you have any questions feel free to ask I’ll help as much as I can:drive:
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6482
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6485
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6484
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6481
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6480
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6478
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6477
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6468
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_6469
madsedan
Dallas
23 CW Type R
Does this get you the magical pops/burbles people like about the type s or is it just a cheap upgrade?
HRace
United States
Honda Civic
I’m hoping when Hondata adds the pops/burbles tune, this mod will allow it to sound as good as the DE5 does without that extra resonator.
HRace
United States
Honda Civic
@JDM_DOHC_SiR Pics are super helpful. Thanks. I couldn’t figure out how you dealt with the flared tubing of the center tip. Just cut the flared portion out and weld the larger pipe diamater of the tip to the center can. Nice. Outer tips look like it’s basically slipped over top of the smaller pipe from the outer cans and spot welded. Sound about right?
JDM_DOHC_SiR
Uncle Dave
Chula Vista
The tubing for the center tip once you cut the 5” off it slips right over the center section for the CTR exhaust perfectly and same with the outer tips as well. In the pictures I tack welded the tips until I was able to get the alignment perfect.. the. I fully welded the tips on.
Loudogdude
Lou
NJ
23' Honda Civic Type R
@JDM_DOHC_SiR I'd like to keep the stock type r muffler but if I get the front pipe from the Type s to "delete" that front resonator would that just bolt on without mods? not tryna cut anything
HRace
United States
Honda Civic
Unfortunately it’s all one piece for the section with both the resonator and the muffler.
Loudogdude
Lou
NJ
11th Gen Honda Civic Integra Type S Exhaust Swappable? IMG_1329
Shoot for real? We both talkin about the front resonator not the rear right?
theyza
Colorado
2023 FL5
Anyone know anywhere to buy just the three Integra Type S exhaust tips (not the full exhaust setup) to swap with our FL5 tips direct?
I did the front two resonator delete and it sounds way better - louder and get some burbles and pops in Sport and +R mode. I talked with my exhaust shop about doing the rear center muffler delete to get some more noise and swapping all three factory muffler tips to 4” or 4.5” tips - but the inner diameter of tips we could find was too big for the outside two pipes and also too long since an adaptor would need to be made on the outsides. They would stick out too far.
Would be great to just buy the DE5 tips, remove the FL5 tips, and weld the three new big ones on …
The exhaust tips are not sold seperately, not as a Genuine Acura Part anyway. If you absolutely have to have the DE5 tips, the cost effective way to do this would be purchase a used DE5 exhaust, cut the tips off, cut your FL5 tips off and weld the DE5 tips on. You're in for a lot of money for what is essentially a stock exhaust system.
