Club Version
- First Name
- Jose
- Joined
- Aug 3, 2023
- Threads
- 13
- Messages
- 344
- Reaction score
- 563
- Location
- Miami
- Website
- www.youtube.com
- Vehicle(s)
- FL5 Championship White
- Build Thread
- Link
If you want the car to rotate with the current mods, I would suggest first running a reverse stagger tire pressures. Fronts should be around 33 to 34 hot and rears can be around 36 to 37 hot.Tire pressures were around ~37psi hot, starting at ~29psi cold. Toe, according tomy alignment printout is 0.03° total toe front and 0.15° rear
This is why I think I need more front neg camber; it destroyed the outside edge by the sidewall and the understeer just got worse after the first session.![]()
Also, as for the alignment you will want to run a bit of toe out in the front about -0.04 degree each side for a total toe of -0.07 to -0.08 degrees. In the rear you can set it up to be at 0.00 degree.
This should help the car rotate way more, so be careful on cold tires!
