FLRib
Portugal
Civic Type R FK8
So which car feels more hardcore the FK8 or the FL5?
My first CTR was the EP3. IMO, the EP3 feels more hardcore of the all european CTRs . EP3 was lighter and smaller than the next generations. Each following generation added more weight, size, comfort and technology.
Instead of asking which one feels more hardcore or faster, I ask which one is the better car for today's standards.
I liked very much the EP3, but today I can´t enjoy it. So, I hope that FL5 is a better car than the FK8
savagegeese
Savagegeese
IL
FL5 Type R
No idea personally, since I never drove the FL5. The reviews suggest that the FL5 rotates more easily, and that the FL5 dampers in +R mode is more aggressive than a base FK8 dampers in +R, but the FL5 has slightly less steering feedback.
I have the LE ADS in my FK8, so mine is probably similar in feel to the FL5 in full stiff mode. SG mentioned that FL5 +R is a little firmer than FK8 LE, and Thomas at TH stated they are about equal, and since there is a certain range of subjectivity, I'm assuming they are pretty close in roughness.
I'd say that is fair and since it appears any chassis tuning is related to FL5 itself and not a complete ground up re think it is very possible he just tweaked what they did on LE. I'd like to get the FK8 dampers on a Dyno but that maybe too involved.
Boostlag
Arlington, VA
MK7.5 GTI
Are you going to keep the stock dampers or upgrade to something like Olins?
s2kdriver80
Yea, that would be a bit crazy lol. I just wish manufacturers would publish spring and damper rates freely for us car people who are interested. :cool:
michaeljf
MY21 Civic Type R LE
The effects of which I expect would be slightly moderated compared to the FK8 LE given the longer wheelbase, wider track, wider tyres and extra weight.
Speaking to the Australia TCR driver who set the local lap records here back to back in a regular Type R and an LE he said the LE definitely moved around a lot more while the normal Type R was planted at the rear. This is on a fairly smooth FIA Grade 2 circuit and the difference was only a second quicker to the LE in a 2 minute lap.
The question is, where do they go for the inevitable swansong FL5 LE?
Boostlag
Arlington, VA
MK7.5 GTI
from all the reviews I've seen more the FL5 is more stable but FK8 has more rotation. I guess you can fit a bigger rear sway on to the FL5.
ayau
Subaru
My 93 Civic feels the most hardcore but that doesn’t mean it’s a better overall car than the FL5 platform.
The FL5 receives all the engineering benefits from the main Civic. Many of those benefits aren’t visible to the average owner. Sometimes that adds additional weight but hurts straight line speed. This is just one small metric. FK8 owners will always need to justify why their car is “better” than the FL5.
There should be more discussion on the chassis updates and less on 0-60.
sackofcheese
Andrew
Central KY
Just curious if you have time slips for your autox times compared to your local FK8’s. I find that hard to believe no offence.
Granted this is RAW time, but I typically can run fairly close to the FK8s in my region. Plus with the soft PAX the Si gets it jumps me way up overall.
(For the record, this was one of my worst showings as a driver this year)
11th Gen Honda Civic Thoughts on FL5 vs FK8 (by savagegeese) CKR results PE8.PNG
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
The stigs review indicates the opposite. Said that the car was engineered to understeer and not rotate, unlike the Elantra N.
savagegeese
Savagegeese
IL
FL5 Type R
The chief engineer never said that.
FK7_
BC
2017 Civic Hatchback sport
Impressive. Jump in an FK8 (or FL5) and I bet you’d throw down way faster times.
BoostedDreams
Heisenburg
South East Florida
Correct. I didn’t say chief engineer though. The Stig said the “project chief” or “large project leader for this car” likes understeer and it was evident. If that’s considered a chief engineer then I don’t have much to add. Just sharing the video and his feedback.
s2kdriver80
Weird, not sure what to think. The Straight Pipes and Verstappen claimed this new car had less understeer. Also, in SG's video, they seem to imply the newer model rotates easier (but he can chime in to clarify). And a couple of other videos (forget which ones exactly) which reflect similar sentiments.
Could be the tires (some reviews might be done with Cup 2s vs PS4Ss) and different tire pressures as well that give different impressions.
BoostedDreams
Heisenburg
South East Florida
Probably a lot of variables, but in that video he’s straight up claiming that this Hideki Kakinuma designed the car to have a stuck back end and under steer. I’m sure the aftermarket will fix that if need be though.
savagegeese
Savagegeese
IL
FL5 Type R
I wasn't being confrontational, just saying we never heard him say that, in fact even with translation issues that guy would hates understeer.
