๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal
tezzasaurusrex
tezzasaurusrex
Terence
WTAC 2025 is done and dusted.
We finished in P3 - Tuner Class - against much higher powered, higher budget machinery.
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 20250906_214025
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal IMG_20250907_072132_470
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal PRACTICE DAY-4935
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal PRACTICE DAY-4896 (1)
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 250906_tuner_0302
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 250906_tuner_0294
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 250906_tuner_0296
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 250904_WTAC_day0_0223
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20250909_001021_Gallery
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal Screenshot_20251118_071056_Chrom
joshinthecity
Josh
Sydney Australia
2025 CTR. Championship White.
The result is fantastic. The water temp stability is 100% witchcraft. 89c for almost the whole lap !?
Care to share what you know that we don't ?
tezzasaurusrex
tezzasaurusrex
Terence
Main thing is air flow management (ie. prevent the air entering the grille from escaping around the radiator, fill the voids with foam, etc etc) and ethanol fuel.
tezzasaurusrex
tezzasaurusrex
Terence
Alcon TA6+ BBK with TRUSTALIGN spec 355x32 rotor (only 5mm larger in diameter than OE to keep weight in check)
Rotor is 8.5kg which is 1.5kg lighter than OE and all its competitors.
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 20251129_095736
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 20251128_174533
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 20251128_175237
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal 20251128_174612
Djseto
Where did you get this BBK? Is it specific to the FL5 or did you need some custom machining etc to make it fit? Also saw online that this caliper has dust seals. Have you cooked them yet?
tezzasaurusrex
tezzasaurusrex
Terence
Ordered through my local Alcon supplier who gets the adaptors and hats made overseas to suit the specific application.
Yet to track test them as I'm still waiting on endless pads that are on back order until next year so I have no info on the seal longevity but a lot of the local time attack guys run this caliper and I haven't heard of any issues thus far...
Here's the breakdown where you can see the dust seals in front of the piston seal
11th Gen Honda Civic ๐Ÿš€ TRUSTALIGN - Time Attack FL5 Build Journal Messenger_creation_3FED0656-9600-4FE3-8530-AF900E4FB66E
