Xmetal
CTR, S3
I had the same experience with @COBB Tuning and @JST Performance
Both listen to their customers and are extremely responsive.
I am really enjoying my Cobb intake, Jailbreak/AccessPort, and custom tune (on going) by Brian.
I highly recommend both.
My experience with @COBB Tuning on another platform (Audi) have been outstanding as well. But I'm keeping FL5 stock....for now ;):p
nojeebs
nojeebs
25 FL5
That last sentence sounds awfully familiar.
UPDATE on the next addition for the TYPAAHH:
DYME PSI AN fittings. I finished my research on this crazy subplot and am now ready to tackle it. I'm pretty sure I'll fuck something up; but hey gotta fuck up before you fuck down. Rest of the hardware should be coming in tomorrow so I can start mocking up where I want to mount things.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782857254000_R0001231
nojeebs
nojeebs
25 FL5
Rest of the hardware came in and I couldn't help myself to assemble something stupid. Looks like a tachikoma from Ghost in the Shell.
Ok so I'll just list everything I'm using to make this oil filter relocation kit/oil cooler kit (later on). This is completely custom pieced together from my stupid brain as I got the idea from looking at the empty area on the bottom left of the bay. 😅
Parts list:
Improved Racing Low Profile Remote Oil Filter Relocation Adapter (Gen 2)
Improved Racing Remote Engine & Transmission Oil Filter Mount. I plan to add a custom oil cooler later on so I went with the 4 port one. There's a 2 port which will be easier to fit in the space I went with if you decide to do this yourself as well. They also make a 4 port with built in thermostat.
Both those parts require M20x1.5 adapters which they provide when you go through their configurator.
GReddy PRO/SPEC -10 Quick-Release Swivel Hose End - Black / Gold anodized (1x 90 deg and 1x 60 deg) I'm sure there's other angles that can work but this is what I came up with based on a visual inspection.
GReddy -10 ORB male Swivel Hose End(s) - Black / Gold anodized (2x straight ORB)
Dyme PRO/SPEC ORB (Standard) Adapters (2x ORB 10 Male PS Size: 10)
Also get some thread sealant for the 2x Dyme adapters and 2x Greddy straight ORB ends. I use LOCTITE 565. You'll also want some oil to apply on the fittings when threading them together with the hose. Whatever engine oil you have around works. Also get LOCTITE 263 (RED) for the M20x1.5 adapters.
I picked up 12ft of GReddy -10 Nylon Braided Hose(per/ft) - Black / Gold / Blue. Probably don't need this much but I got some extra in case I fuck up. Also after test fitting the oil filter relocation mount I noticed the radiator reservoir tank hose looks like a -10 as well.
But yeah once you look under the car and above you'll get an idea on where the route the lines. Which is the part I'm currently on. Oh, I use an existing mounting point in the bay and just added a spacer (in the photo it's 3/4" tall but I'm going to push out the mount further away from the chassis so I got 1 1/2" and 1 1/4" coming in to test out).
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782929143000_R0001239
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782929203000_R0001241
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782929385000_R0001245
These quick fittings are overkill but they'll help with assembly and disassemble when the time comes to add an oil cooler or if I just want to take a hot oil bath without getting under the car.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782930154000_R0001252
Plug to stop oil from getting everywhere if they're disconnected.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782930257000_R0001254
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782930288000_R0001255
-10 Greddy hose. All the Greddy hardware is produced by DYME so you know everything will fit perfectly together. Even though everyone uses AN sizing numbers it doesn't me the OD of the hose will be exactly the same between brands.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260701_222242727
First test fit. I originally wanted to mount it in the space between the motor mount and crash beam mounting point but I didn't want to get a custom bracket made as the Improved Racing 4 port I chose only lets you mount it one way. I think the one with the thermostat gives you 3 mounting choices. Ok I went to go look at the product again and it wouldn't really help if you want to have the filter pointing up; which is one of the main reasons of doing this in the first place.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782950087000_R0001260
Tight so that's why I ordered longer spaces to try out.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1782950172000_R0001262
Alright my daughter is asking why I'm taking so long. Peace.
scottjua
Scott
Plano, TX
Got a random uptick of people asking how I mount the pins on the interior mesh/grill. Figured I'd share the video here as well for preservation purposes haha.
Awesome! My RA272 came in and I hadn’t gotten around to fitting it yet. This helps a lot!
Dammit, I think you just sold me a Cobb.
It's funny and I don't want to derail the thread because this is the best one on the forum- but I just picked up an ND3 Miata as a side quest, and while it is amazing in its own right it actually made me appreciate my DE5 just a bit more. All I have is an Infinity Design intake and Invidia exhaust, and getting into the DE5 after driving the MX-5 around it feels like a rocket ship. I've always actually been a wet blanket for people that go for big power on this platform- still leftover vestiges of my bias against FWD- but I'm really starting to come around on this K20 and the way it delivers power.
I think I've arrived at the point where I feel like just a bit more wouldn't hurt anything. And I've had a custom Cobb tune on an STI in the past that exceeded expectations.
Shit.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build the-office-declare
Shit.
This is how the rabbit hole starts getting real big, really quickly lol
0x1d7
Washington
2025 Civic Type-R
$1600 for full upper dash with core exchange
Damn. Okay, good to know. These folks are thinking they would have to disassemble the dash (steering column, etc etc) which would be 6 hours out, 6 hours in, plus the time for applying the Alcantara.
Would be cheaper to drive down to LA...
nojeebs
nojeebs
25 FL5
Oh I misread your question....this is going to hurt more though...install was $900. The $1600 was the price for the dash + core exchange.
nojeebs
nojeebs
25 FL5
Xtreme-Di Evo + 1400cc injectors has arrived! I'm just looking to make good reliable power for daily and track use....just mid 400s on 91 and I'll be happy. Not sure what kind of torque numbers to expect with this entire setup. Oh still waiting on downpipe as well so that'll be another egg to crack.
Right now my issue is I need a base tune to make sure the pump can run. One of the downsides to using AP over Hondata is that I can't just tick off a box to active the pump and just continue on until I can get it tuned.
Well if anyone wants to see up close what this pump and one of the injectors looks like here's a quick set:
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783572786000_R0001295
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783572828000_R0001297
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783573118000_R0001304
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783573287000_R0001311
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783572987000_R0001298
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1783573364000_R0001314
TchnoZ33
Zaid
Indiana
What made you decide to go with the XDI HPFP versus the full race HPFP?
nojeebs
nojeebs
25 FL5
Recommendation from several tuners and people I know that have them with zero issues. I know full race fuel line keeps failing on track and they've been through 3 revisions. I'm not upgrading that as of right now but that just spooks me especially since I'll be tracking the car.
iforgettopee
jeff
los angeles
it'll be pretty amazing if you can hit 450whp on 91 - good luck
400-420ish is what i see on 91 pump gas, on avg
you could probably hit 450 with 93octane, but gonna be tough on 91
let this be motivation to get those flexfuel parts 😉
it's also not too late to switch to Hondata 🤣
