Rear vents/USB port mod
Nothing
2023 CW FL5 #5044
Hmmm. I'm gonna have to do this! Just gotta find the time! Great pictures and discussion.
us17094
Tenny
Accord 2.0T 6 speed
Based on the design, is the idea that this diverts part of the air flow that would otherwise come out from under the seats to the new vents? I wonder if this means there would be no back air vent airflow unless you switched the AC to the foot/floor setting. The foot/floor vents aren't on often when using the auto cool function (at least it seems that way to me). Can anyone who has this installed provide their thoughts on this?
BC504
New Orleans, LA
2024 CW CTR
It isn't diverting any flow, it's opening a path for the air to make it to the back from any mode setting other than defrost. The photo below compares the oem floor tube (bottom) to the new splitter tube (top). When on the face setting, the HVAC door was closing off flow to the floor vents on the oem tube through the single outlet. With the new splitter, the door closes on the floor outlet but leaves the new rear outlet open. Essentially the air from the factory was hitting the blocked off portion of the oem tube with nowhere to go.
11th Gen Honda Civic Rear vents/USB port mod IMG_3947
There's a noticable reduction in airflow from the front vents with the rears open, but it's nothing horrible.
Yayo
Hermann
Spain
FL5 MY23
Install was easy, took about 1.5 hours and took my time dremeling and trimming the rear panel. I was expecting the shift knob collar to give me trouble but it popped off easily after rotating it 90 degrees and twisting back and forth while applying downward pressure.
The factory outlet that feeds into the footwell vents was a bit of a pain and I wound up breaking the two rear clips even when prying the tabs with a plastic tool so be careful.
Fitment on the rear panel is decent, the upper left won't sit flush even after all the trimming but it isn't something anyone would see.
Looks very very nice. Congrats
Nothing
2023 CW FL5 #5044
I would read "diverting" to be splitting off flow, not necessarily wholly redirecting flow. To this end, since the blower is the fixed constraint, and your feedback that front vent flow is reduced at a given fan speed, yes the floor vents would be reduced. If the blocked plate didn't allow flow, additional flow would go through the other openings unless there was a significant restriction that is likely stalling the fan a bit (which is unlikely for OEM). Perfect example of this is close all vents except one and you'll feel the air flow increase. Works the same in your home for central air.
For me I rarely have the AC on higher than lvl2 at 76F, so I could stand to crank it up a little if my kids get air in the back.
Djseto
Sorry the Mikstore stuff all came without packaging or part #s so no help there. It certainly seems like an OEM part to me?
Here's JDM_DOHC_SiR's list they used:
83451-T24-T01ZA : Rear A/C Panel x1
83406-TVA-A01ZA : Rear A/C Vent x1
83453-T24-T01 : Rear A/C Duct x1
83460-T43-J00 : Front Lower A/C Duct x1
83465-T43-J00 : Rear Lower A/C Duct x1
91550-SFJ-W01ZE : Clips x3
Based on this:
https://jdmyamato.com/products/nhp001628
Looks like the splitter is on another diagram so I don't know the part #, maybe ping JDM and see if they have a part # used and not listed, it's possible they decided to not use the splitter and just go with no floor vent (I think you can do that).
Was this a feature only forJDM Civics or are their certain USDM models that had this?Might be easier to find a salvage yard car if USDM. I'm also tempted to do this mod for my kids as well. The cost of the parts isn't bad but $94 shipping sure irks me...
Samurai1225
Chris
Cincinnati
Just got mine installed. I'm very happy.. there is no discernable loss in flow from the front vents. The USB's are illuminated and the USB "c" is nice to have.
11th Gen Honda Civic Rear vents/USB port mod Rear Vents
stale_hotdog
R
civic type r
Fitment looks great from that angle. Any issues during fitting? Also, I’m assuming there’s a huge hole inside the glovebox compartment?
Samurai1225
Chris
Cincinnati
Fitment is great. Full disclosure I have a guy who owns a small car audio shop and I had him install the vents. He also hard-wired my dashcam. And no there are huge holes in the glovebox. Not even a small hole.
2023 CTR #3177 (stolen)
The hole was needed on the earliest versions of this. Current version is mostly plug & play, only the (new) rear panel needs some trimming to fit properly.
Some airflow is diverted but it's fairly negligible - or, IOW, here in Miami I'm not regretting it up front at all and my kid in back is thankful.
Rear A/C has never been available in US market cars, not even in the Accord.
Starman703
RTP, North Carolina
For those that recently purchased this item, does the kit already come with the USB ports or did you have to also choose the USB option?
How long did it take for the kit to arrive after placing order?
11th Gen Honda Civic Rear vents/USB port mod Screenshot_20241123_103927_Edg
Nothing
2023 CW FL5 #5044
I think it only took a week or two. For international, I tend to just order and forget about it, it is less painful to think about how long it'll take. Haha.
When I ordered there wasn't an option for usb-c but it came with it.
Evox787
Elvin
Ok to post on the thread I order the fl5 from milksostore but didn’t like the fitment of the rear vent too much. Somebody here put the OEM part number I bought them on JDM Yamamoto. This what I got:
83451-T24-T01ZA x1
83453-T24-t01 x1
83406-TVA-A01ZA x1
91550-SFJ-W01ZE x1 to the centrer console tube that comes from the Front
93913-24220x3 for the vent.
The usb connection it was transferred to the honda one and the fitment is without any weird spacing.
11th Gen Honda Civic Rear vents/USB port mod IMG_0370
11th Gen Honda Civic Rear vents/USB port mod IMG_0371
11th Gen Honda Civic Rear vents/USB port mod IMG_0372
Evox787
Elvin
@Evox787 Cost wise, was it similar to getting it from the Mikstore?
I still got the mikstore kit + the oem vent because of the fitment and the modifications that needed to be done to the kit doesn’t really fit the way it supposed to. I pay 273.12 for the kit and 141.47 for the oem parts but I bought couple of bolts and clips extra that I did not use. Because I look for the oem parts ant the part that diverts the air isn’t sold separately from the heat core or the part that is under there it was expensive. But all works perfectly for me and the shipping was fast for both mikstore I got it like on 3 days after I ordered and the JDM Yamamoto like 5 days after order.
