*The FL5 Track Junkie Thread*
Rexpelagi
John
Nashville, TN
www.youtube.com
I don't mind the changes; I just don't like getting the quick jacks setup ? I wish I had room for a more permanent setup.
1st world problems... ?
If you don't already have one, a power bleeder with the correct adapter makes it painless, as long as you keep an eye on the reservoir fluid level as you go.
So you guys flush the brake fluid at the beginning of every season?
Rexpelagi
John
Nashville, TN
www.youtube.com
I usually don't do a full flush specifically but I do several good bleeds during the season every few events, which likely equates to at least a flush per year if not more.
So you just put in a bit of new fluid after a few events. Got it.
Rexpelagi
John
Nashville, TN
www.youtube.com
Yep, which doesn't mean it's right, but it's worked so far lol. However, the "a bit" of fluid is probably at least 250ml if not a full 500ml bottle - not sure what the system holds, but I'm guessing it's fully flushed within 2 "bleeds".
I also pay attention to differences in the pedal feel even around town - if it starts to feel off I'll do it regardless of timing.
I don’t track as much as you guys. Avg around 3 track days. So most of the time I don’t change fluids maybe after 2 seasons and never had issues or real feel changes.
BigBird
SRF is really good at being moisture phobic. opened bottles a year later still does not absorb moisture.
This car is my least favorite car to bleed. I can't pressure bleed since i can't find a cap that holds the pressure. And all the kits I found for a compressor never worked right or took way too long. My kids have been the best as we do it old school.
I use a vacuum bleeder connected to my air compressor.
hmmmm I had no issues using a pressure bleeder. This is the cap I got
https://www.amazon.com/gp/product/B09SNNSLK7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
pressure stays where its suppose to be (I also use a smotive bleeder which is a copy of the motive one but imo better). I have used it once and was easy as pie
I flush every every year and by flush I just get almost a litter through which should be all of the fluid. I don't drain the system or anything like that, just get it through every caliper as much as I think is necessary and thats that. Then send the old shit back to FCP euro and get my $90 back
Rexpelagi
John
Nashville, TN
www.youtube.com
This one works:
https://www.amazon.com/dp/B01MYXAXS5?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
I use it with this:
https://www.amazon.com/dp/B000TK9FE8?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
You'll need some fittings to adapt the line over (some you may have already):
https://www.amazon.com/dp/B085X68CMJ?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
https://www.amazon.com/dp/B07D9D2BS1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
https://www.amazon.com/dp/B0CTFLDZG3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
BigBird
with the smotive you need nothing, it just quick clamps in. There is some things about the copy cat smotive pro that I liked better than the motive so thats what I went with. Happy with it, for the price and don't have to mess with air compressors or air from the tire as a compressor, it just works
looks like I tried that one and think it leaked at the valve. I didn't return it, but may try it again.
thats a bummer, yeah mine is totally fine and has done a couple bleeds so far.
what a winter day, we talking about brake bleeding lol
