*The FL5 Track Junkie Thread*
ctechauto
We installed a whole bunch of suspension on our shop FL5. We were running on Eibach Sportline Springs for a bit while we got our suspension package in place.
You can find all the parts on our site which will be link embedded!
We can also have a custom packaged deal with a discount depending on options like the Sakebomb camber plates (we are official dealers for Sakebomb Garage/FPSpec), EDC canceller, helper spring upgrade, custom spring rates etc. PM for more information!
- Ohlins R&T (stock 6k/10k springs) and Ohlins helper springs upgrade
- Sakebomb Camber Plates/Top Hat
- Awaiting our Swift Springs 6" 6k springs to come in then we'll swap out the front springs (fine balance between aesthetics and track functionality; we're good with losing a little bit of compression travel for more lows and we can always raise it up for track days if needed)
- Ohlins EDC Cancellation Kit
- Whiteline Front Lower Camber Ball Joints
- Whiteline Front Sway Bar Endlinks
- Whiteline Rear Lower Toe Arms
- Eibach Rear Upper Control (Camber) Arms
11th Gen Honda Civic *The FL5 Track Junkie Thread* 1747784318640-t3
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5295
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5258
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5299
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5270
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5284
11th Gen Honda Civic *The FL5 Track Junkie Thread* DSC_5291
We set the front LBJ to max camber pin setting (-3*), upper strut guide pins were already removed previously on the old set up, and adjusted the upper camber plate to farthest out (no additional camber).
Eyeballed everything with regards to camber/toe/caster and went to our friends shop for the alignment rack. For being eyeballed, I think we did pretty good all things considered :)
Wanted at least -3.5* front and -2.5* rear camber, and this was initial reading.
11th Gen Honda Civic *The FL5 Track Junkie Thread* 1747787767802-ko
Final reading:
11th Gen Honda Civic *The FL5 Track Junkie Thread* 1747787796568-53
11th Gen Honda Civic *The FL5 Track Junkie Thread* 1747787824751-qm
Overall very happy with how it turned out! Once our Swift Springs come in, we may move the LBJ camber pin to the middle setting (-2*), then adjust from the top camber plate in order to reduce a little bit of the gained track width from camber adjustment from the LBJ as we're planning to run aggressive wheel specs and tire size once our shipment arrives! Also if you're in the North Texas DFW area, we can get all this installed and knocked out for you.
Rexpelagi
John
Nashville, TN
www.youtube.com
Final reading:
Based on my experience I think -4.1° front camber is quite a bit too much for track use, at least with increased power, although others may have different experience. I lost a lot of corner exit capability and also destroyed the inside of my tires at around -3.8° with ~370whp. I've now backed camber down to ~-2.8°. Curious how this one performs, although your spring rates are quite a bit lower than mine which may be a factor as well.
ctechauto
Yeah, it could be too much, but we'll see. Also driving style has a lot to do with it too. Our track Cayman we run -3.2⁰ and its right on the money, but its obviously not a FWD FL5. Although we're also trying to balance track function with TA style aesthetics too. Talking to Racebred right now ;)
Rexpelagi
John
Nashville, TN
www.youtube.com
On a strut front RWD car I'd say -3° is probably the minimum, and I'd probably go more like -3.5° to -4°, but ya obviously there are much different dynamics on the FL5.
Aesthetically it looks great though!
Why get the ball joints and also the camber plates? can't you just get what you need for the camber plates alone?
ctechauto
Multiple adjustment options is never a bad thing. Also if you want to increase track width as a side-effect of the LBJ you can/will. Also the camber plates can also adjust caster independently so also another plus.
Similar to Porsche platforms - many double up on using LCA to adjust camber as well as camber plates both to fine tune camber and track width/scrub radius. On our Cayman we have camber plates that are maxed out at that -3.2⁰ that was mentioned, if we ever needed more we would need to do the LCA in addition to.
Rexpelagi
John
Nashville, TN
www.youtube.com
(Hopefully) ready to go at Gingerman! We had practice today and I'm finally starting to get some consistent predictable rotation - I've changed to 16kg/mm rear springs (up from 12kg/mm), and settled on ~1/8" total toe out in the rear for the time being (changed from 1/16" toe-in which was the factory setting), with +10psi in the rear and the 285/255 reverse stagger. Looking forward to the official timed sessions over the next 3 days!
11th Gen Honda Civic *The FL5 Track Junkie Thread* 1000020548
svvitch
Gingerman is fun and a pretty safe track to test extra rotation ? good luck this weekend ?
m3bs
South Carolina
2023 CTR, 2016 GT4
Makes me cringe to think about cresting turn 10 at VIR with rear toe-out….but most of my setup experience has been with RWD.
ctechauto
Swapped in some shorter Swift springs to get more lows. Probably will move the LCBJ to the middle setting and go to -3.2 ish camber depending on how the wheels and tires sit when they arrive late summer/early fall. Although right now at -4.1 the front stance looks fantastic, albeit probably a bit excessive.
Rexpelagi
John
Nashville, TN
www.youtube.com
Day 1 update: managed a 1:38.7 in session 1, although the lap was impacted by traffic as they started me in the slowest group (Group D) for reasons unknown. I was then bumped to group B, but the surface fell away after the morning as usual. I believe this puts me in 5th in class for the time being.
We'll see what I can do tomorrow morning!
ctechauto
Day 1 update: managed a 1:38.7 in session 1, although the lap was impacted by traffic as they started me in the slowest group (Group D) for reasons unknown. I was then bumped to group B, but the surface fell away after the morning as usual. We'll see what I can do tomorrow morning!
Nice driving man! Where is your mic (if any) set up? It sounds like you have an external WG dump lol
Rexpelagi
John
Nashville, TN
www.youtube.com
I run an external powered mic on the back bumper - it's mainly just to cut down on the wind noise. I'm still on the stock exhaust after the mid-pipe so it's not anything special sound-wise ?.
