XDI or Full Race HPFP
HondaHoon
Western Maryland, USA
You guys ready for more chaos to add to this. Read this. This is in reference to the soft line that has been debated works/does not work. From what I gather from this, is that all these companies cradle each others balls, and none of them are going to do the right thing and make a soft line that works with the Full Race pump period.
11th Gen Honda Civic XDI or Full Race HPFP Screenshot_20260713_153129_Gmail
11th Gen Honda Civic XDI or Full Race HPFP Screenshot_20260713_153135_Gmail
25_BlackFl5
KSA
2023 LC300 Toyota Land Cruiser TT, 2025 Civic FL5 Type R
So it'll only work on XDI HPFP? Either way, this HP fuel line with an XDI HPFP, I believe would be more reliable since its a stock fuel line that's been modded and I haven't seen any issues of line cracking. I still have the HPFP, but I've been thinking of upgrading the turbo, but this high pressure fuel line issue is keeping me from doing so.
TchnoZ33
Zaid
Indiana
Me too man, which is why this thread was started.
25_BlackFl5
KSA
I still want to hear from the people that use the JSR OEM modified High pressure line. From what I've seen people from the FK8 forum, people were using this line with the XDI pump, with no issues, especially as this was the only solution before the Full Race HPFP.
I drilled my factory line, so it's essentially the same as what JSR has done. No issues to report.
25_BlackFl5
KSA
Any update?
Also I wanted to ask a few things related to the this topic:
1. Does the XDI, not come with a HP fuel line? If it does would the JSR option be a better option?
2. If I installed the canflex, I've seen that most people also change some parts on that, but I not sure from where can someone explain this to me.
3. If I do install the canflex and upgrade the HPFP do I need a filter for the fuel system, if so what is the best and why?
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Update on my fuel system install, pasted from another thread. This is the summarized version:
We had a few questions on the XDI HPFP flex line that got answered along the way. Both ends of the line are identical, it's rated across all fuel types (including ethanol, race gas, methanol, even hydrogen in motorsport use, though XDI doesn't publicly advertise fuel compatibility to protect their manufacturer’s IP), and 3 1/2 threads engagement into the fuel rail is normal, hand-snug is really all these need before a final wrench pass.
Install came back together clean, checked every fitting before first start, no leaks at the HPFP, and it settled into a smooth idle after the initial crank cycles as expected. Idled 15 minutes with no codes, then took it for a shakedown drive on the basemap with no inconsistencies.
Logging is now underway for DRob ahead of the dyno. Got a 60-mile drive in with the 15-minute steady cruise and WOT 3rd-gear pull from 2000rpm both logged, still need to recapture the 15-minute stop-and-go (FlashPro missed it twice) and the cold start/idle log (FlashPro missed this as well 😬), planning to grab both tomorrow. Full tune on Shell 93 and Ethanol is expected in the next 1-3 weeks.
11th Gen Honda Civic XDI or Full Race HPFP IMG_8977
11th Gen Honda Civic XDI or Full Race HPFP IMG_8978
11th Gen Honda Civic XDI or Full Race HPFP IMG_8985
11th Gen Honda Civic XDI or Full Race HPFP IMG_8995
11th Gen Honda Civic XDI or Full Race HPFP IMG_8979
11th Gen Honda Civic XDI or Full Race HPFP IMG_9030
