FL5 Overheated on Track
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1744309943039
I want to share some pretty exciting news for the Type R track community! I have been working with PWR over the past couple of months and they/we will be releasing 2 versions of a triple pass radiator for the FL5 (and possibly the FK8 depending on demand).
One version will be the PWR version, and the other will be the WOT Performance by PWR version. I'm going to call it WOT spec for short.
In a general sense they will be very similar in design and concept, and both should perform extremely well. The triple pass design forces the coolant to travel along a longer path within the core, allowing it a longer period of time to cool down before traveling back towards the engine.
The WOT spec will have two primary differences:
1) More track oriented custom core spec: higher fin density, and special fin louver angle to further improve heat transfer.
2) Integrated bracket for optional transmission cooler: Built in provision on the back side of the radiator to easily add an optional transmission cooler to further reduce coolant temps by unburdening the coolant system (the OEM design uses the coolant system to cool trans fluid via the heat exchanger on the front of the transmission). The placement on the backside of the radiator is to minimize interference with the radiator and maximize efficiency.
The idea is that the PWR spec will be a massive step forward from the current track spec single pass that's available, and WOT spec will be the ultimate level stock replacement radiator available.
Both the PWR spec and WOT spec should be available in the coming weeks. Official pricing is still yet to be determined but should be in the $1400ish range (plus shipping) for the PWR spec, and $1600ish (plus shipping) for the WOT spec, with the transmission cooler add add on available for around $200.
The core of both specs will be 42mm (same as the current PWR track spec single pass radiator), and the other dimensions will also be similar with some slight changes to accommodate the different end tanks. Both specs will be a direct bolt on and will work with OEM fans and other components.
If you would like to pre-order either spec to be one of the first with this on your ride contact me. I will be the only vendor offering the WOT spec.
The picture in the post is a stock photo of the PWR track spec single pass radiator, currently there are no images yet available, but as soon as there are I will add them.
I recently hired someone to help me finish designing my website and it should be up and running here soon.
west357
Matthew
ohio
honda civic type R
Has anyone just removed the trans cooler/heater and then tracked the car in warm temperatures? Also how involved is the modification? My car is 100% stock under the hood and I’m contemplating doing this first. My local shop has recommended starting here (they support an extremely fast time attack Honda civic that laps 1:24s at Mid Ohio). So I do think they know what they are talking about.
svvitch
I don't know the temp trans fluid reaches on track. But plenty of Honda transmissions without coolers. I feel this was installed to warm the fluid in cold climates vs cooling the fluid on track.
Cold fluid probably reduces efficiency in cold climates and simply takes to long to warm up without the cooler/heater.
siwelnosaj
Jason
Reno, NV
Type R
That could make sense on a time attack car but I would be worried about the trans fluid getting too hot and also not getting proper warm up with the method used. I can't say for sure but those would be my concerns.
With my kit you'll have 2 options for install. Bypassing the piece you are talking about which would unburden the coolant system completely, but it also means you won't have the OEM warm up design of using coolant to warm the trans fluid (really just depends on your climate and use plans)
The other would have the trans cooler tap into the OEM piece so that warm up still happens via coolant, but the supplemental cooler helps significantly with trans fluid temps and the coolant system doesn't have to carry the load.
For what it's worth the TCR cars also use a transmission cooler. Time attack makes sense cause it's 1 or maybe 2 hot laps usually and then the cool down. They usually don't even need much in the way of cooling mods
siwelnosaj
Jason
Reno, NV
Type R
The physical units are being built currently but here is the final design of the FL5 WOT spec triple pass radiator with transmission cooler! There is also an FK8 version in production and it will in essence be the same with different mounting points specific to the FK8.
PWR will also be releasing their own spec here soon. The WOT spec will have two primary differences:
The idea WOT spec will be the ultimate level stock replacement radiator available.
This will fit just like the current PWR single pass radiator. No modifications needed, works with the fan and works with various intakes.
If you would like to order either spec contact me and I can set your order up. I will be the only vendor offering the WOT spec.
Price is $1600 without the transmission cooler attached (but can add it later since the bracket is on), $1800 with the transmission cooler, lines, and clamps. $120 for shipping, so $1720 or $1920 depending.
PWR spec will be $1400 plus $120 for shipping so $1520.
You have the option to plumb the transmission cooler in 2 ways: 1 is to integrate it with the OEM heat sink piece to maintain OEM warm up using coolant, or #2 is to completely bypass the OEM heat sink but at the cost of losing OEM warm up.
FK8 version will require the removal of the passenger side fan, but in talking with the PWR engineering team they feel confident this will cause no issues on the street and on the track it will actually help by removing resistance on the back side. I ran my FK8 daily and track for 2 years without the passenger side fan with zero issues even in 105+ temps in the Reno summer.
11th Gen Honda Civic FL5 Overheated on Track Screenshot_20250425_073900_Driv
11th Gen Honda Civic FL5 Overheated on Track Screenshot_20250425_073928_Driv
11th Gen Honda Civic FL5 Overheated on Track Screenshot_20250425_073958_Driv
11th Gen Honda Civic FL5 Overheated on Track Screenshot_20250425_074018_Driv
11th Gen Honda Civic FL5 Overheated on Track Screenshot_20250425_074045_Driv
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic FL5 Overheated on Track Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 2 (Turn 2)-CPRP5092_Apr2725_839AM_CaliPhot
11th Gen Honda Civic FL5 Overheated on Track Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 1 (Turn 3)-CPRP4150_Apr2725_705AM_CaliPhot
11th Gen Honda Civic FL5 Overheated on Track On Track Oil Temperature Comparison-1
11th Gen Honda Civic FL5 Overheated on Track On Track Coolant Temperature Comparison-1
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1745866505787
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1745866788162
Massive results during track testing yesterday!
Dual oil cooler set up is working and working well. Still need to make a couple of small adjustments on fitment and finalize brackets, but given yesterday's results with the prototype, it showed it's ready to perform. Hopefully I can get these adjustments made in the next few weeks and officially put the kit up for sale. Best part is you can't even see that there's oil coolers on the car, OEM+. I'll share pictures when it's ready for sale.
Testing was done in 2 parts. Saturday ran with no oil coolers, no cooling plate, OEM radiator. Sunday I added the oil coolers and later the cooling plate. Ambient temps were low at 62°, but this testing was about relative performance, 1 for 1. Oil temps were measured using a physical sensor added into the oil pan (post engine and pre oil coolers so it's at its hottest). Coolant was measured using the OEM sensor in the head.
On Saturday to create a baseline, the car was run in OEM cooling form (OEM radiator, OEM under tray, no oil coolers) I got the car to the limit with a peak oil temp of 290° and coolant up to 249°. This was in a session where I had my last 5 laps averaging 1:55.66 on the new Buttonwillow "The Circuit".
Sunday with the oil coolers added, peak temps dropped to 255° for oil and 219° for coolant. In this session I had the last 5 average 1:55.21. A giant 35° improvement in post engine oil temps, and 30° in coolant temps!
When the cooling plate was added, peak temps dropped again with oil at 249° and coolant down to 206°. Last 5 laps averaging 1:54.41. Another drop of 6° for oil, and 13° for coolant!
I experienced zero aero issues with the cooling plate added, I achieved my highest top speeds and highest lateral Gs with it on the car, 128.4 mph and 1.46 G respectively.
I will be returning to The Circuit in 2 weeks to run the WOT spec triple pass radiator and transmission cooler and I'm hopeful ambient temps will be in the 80s or 90s to show that the whole suite of cooling items collectively can get the job done in the heat!
Once I've finalized everything on the FL5 I will be working on releasing the kit for the DE5 and FK8. All 3 cars will have the same modifications available to them.
Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 2 (Turn 2)-CPRP5092_Apr2725_839AM_CaliPhot...webp
Apr-27-2025-Speed Ventures (Sun)-Red Group-Session 1 (Turn 3)-CPRP4150_Apr2725_705AM_CaliPhot...webp
Doing the Lords work ?
Always love it when the fan passion projects outdo billion dollar companies ?
You should change your username to Type R Jesus ?
2 questions.
1. Did you catch a glimpse at all what the OEM oil temperature sensor was reading when you had the oil coolers? Was it still reading 290 F while the 'real sensor' was reading much lower?
2. When you install the WOT/PWR Tripple Pass Radiator, how are you going to run the Transmission lines? I remember there were two different ways to route it.
siwelnosaj
Jason
Reno, NV
Type R
2 questions.
1. When everything was up to temp, the calculated oil was reading about 35° above actual with my set up, about 18° over with no oil coolers.
2. I will run them integrated with the OEM heat sink so that I maintain warm up. I still daily the car and it gets cold where I'm at. It should still be very effective in this configuration though because the trans fluid is still getting cooled the same and so the coolant shouldn't really be pulling heat from it.
Being primarily a track machine, this kind of mod probably makes the car less daily-able, especially when it gets cold outside. Being a track car, they’re probably changing the trans fluid frequently too. Just keep in mind the context of stuff like that compared to your personal goals with your car.
west357
Matthew
ohio
honda civic type R
For sure thanks for your input. For now I’m not planning on removing the oem trans cooler
siwelnosaj
Jason
Reno, NV
Type R
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086129537
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086127303
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086124624
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086122194
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086120099
11th Gen Honda Civic FL5 Overheated on Track FB_IMG_1747086117656
Testing was a big success on Saturday for the FL5 WOT Spec PWR Triple Pass Radiator and transmission cooler! There is also an FK8 version available.
This was a true torture test with ambient temps getting up to 101°F by the last session.
Testing conditions were very different than 2 weeks ago when it was 62° out so it's impossible to create graphs and such to compare, this was more about performance in an absolute sense. Simply put, could the car run on track for full sessions at 100°F, and the answer to that was yes!
The quick summary is that I was able to run all 5 sessions on the day from start to finish without overheating and that I got a personal best of 1:53.5 in the early session when it was cooler out.
When it got to 100° I was only able to manage a 1:56.5, the tires, brakes, and intake temps just weren't as happy and the tires were at the end of their life with this being their 3rd track day and in the toughest conditions.
As I discuss the results it's important to keep in mind that none of the other Type Rs were able to match this pace. The next best time on the day from an R was a 2:02.98 done in the optional 10 minute time trial session and that was in a 2 hot lap scenario, he won his class. His car is mostly stock and his coolant temps hit 242° on the second hot lap with 92° ambient. The other Rs on the day were all around 2:08-2:13 for their best times in any session.
The most telling examples of the radiator's performance were the 4th and 5th sessions where it was 100° and 101° respectfully.
In the 4th session with 100° ambient I ran behind my buddy who is modded similarly but with the PWR track spec single pass. The plan was to run behind him so I could match his pace for multiple laps in a row and then we could compare temps in a more one for one scenario. We were running 2:08 lap times and at the end of the 4th hot lap his coolant was at 233° and was climbing, mine was steady at 219°. A massive 14° difference! I suspect if we did a few more laps the delta would have only continued to grow larger but he pulled off the track.
The 5th session was the real test though. Most everyone had left because it was just too hot out, so they made it a 40 minute open pit for whoever was willing. I filled up on gas and my plan was to run the whole session at an endurance race pace (around 2 flat give or take). There was a black flag right at the start of the session and so it effectively turned into a 30 minute session. I ran the whole 30 minutes in 101° ambient temp at an average pace of 2:01.9. Coolant temps remained stable at 228° - 233° for the 30 minutes. I could have continued but they waived the checkered flag. By the end of the 30 minutes I think I was the only car still on track.
So I was able to run slightly faster for 30 minutes continuously than the next fastest R did as a time trial effort all while keeping temps stable right around 230°. I was able to match coolant temps but keep them steady and go 7 seconds faster per lap for a mega session. Massive success considering the environment.
I am the only vendor selling the WOT Spec PWR Triple Pass Radiator. It goes for $1600, and $1800 with the optional transmission cooler added, plus shipping. If you're interested in one for yourself message me and I can set up your order. They are build to order with an approximate 4 week turn around shipping direct to you from PWR.
Direct bolt in, no modifications needed.
Message me if you have any questions or would like to set up an order.
simpleisbest
So. Cal
2023 CW CTR, 2023 Subaru BRZ
Awesome results! We you also using an oil cooler this day and do you remember what range your oil temps were also at?
siwelnosaj
Jason
Reno, NV
Type R
I was using my prototype oil cooler kit and in the 4th session oil temps were around 255, in the 5th session they were around 264.
