*The FL5 Track Junkie Thread*
naafl5
Maryland
Plug in a code reader, from my understanding it should show the over rev code (p0219) if it was a big enough over rev.
@MooMoo I created a new thread about a similar situation.
Do you know if my Hondata flash pro would be able to detect the code?
If it can detect it, I’m assuming you can’t clear it with the Hondata flash pro either?
not sure if hondata can see the code.
Don’t think code can be cleared, gets permanently stored in ecu
Hondata flash pro can detect and clear the code. You can use the phone app to do the same.
naafl5
Maryland
I'm reading conflicting statements on the ability to clear the code.
Only reason I ask is because I'm a bit OCD thinking maybe I accidentally hit "Clear DTCs" while fumbling through my Hondata desktop application. It isn't the most intuitive piece of software haha.
Anyone know if you're prompted with "are you sure?" or some kind of confirmation screen when you do attempt clear DTCs?
Either way, taking it to the shop and hopefully they can also read historical codes.
I had a code prior and was able to clear it with my flash pro.
11th Gen Honda Civic *The FL5 Track Junkie Thread* IMG_2434
naafl5
Maryland
Do you remember if it asked you to confirm with something like "are you sure?" or a "warning this will clear all codes, make sure you fixed everything first".
I don’t remember but guess there is. Clearing doesn’t fix the issue so if the issue is unfixed, the code will appear again.
Rexpelagi
John
Nashville, TN
www.youtube.com
It sounds like my shocks are stateside now, which is good because CMP is only a month away :oops:.
For those that have installed coilovers, is there any particular brand of shock sensor disablers that is preferred (ie, the cheaper the better if it actually works)? Also, if you don't install them is it just a light on in the background, or are there constant warnings / beeps / etc?
Haven't watched the whole video yet but I've heard about how racing slicks can affect a car. Did you notice any drop in oil pressure?
johnny.silva7
Jonathan
Austin
(FL5) Civic Type R, Viper TA
Wild weekend at MSR Houston last week. I managed to capture some gnarly footage of track debris ending my weekend early at MSRH. Right after the outlap of a session, my windshield shattered from debris kicked up on the track. I consider myself lucky it didn't pierce the windshield or slam into my front bumper.
11th Gen Honda Civic *The FL5 Track Junkie Thread* Copy of PXL_20250308_212458932
Despite ending early, I was able to run 2 laps without traffic:
BigBird
First time I've seen that happen. Glad all is safe and only the windscreen
Tougefl5
KW is the cancelation module to get. Two of mine got ruined by a bad install job from a authorized dealer. KW sent me 4 replacement modules no questions asked. If you don't install them then you will be stuck in sport mode not able to switch drive modes.
