FL5 Overheated on Track
BuntaTypeR
There are many factors contributing to the FL5's tendency to overheat, including the day's temperature, driving style, track conditions, and even airflow blockage from cars in front. In my experience, anything above 85°F has led to overheating, which I observed during testing at Willow Springs and Streets of Willow. I've even run my FL5 in 105°F weather. Now, my car has extensive modifications for cooling, some of which are custom and not available on the market. Since temperatures are dropping, I won’t be able to fully gauge the impact until summer returns, when I can properly test if the overheating issues are resolved.
siwelnosaj
Jason
Reno, NV
Type R
I'm wondering if you'd be willing to share your cooling modifications?
So as a someone who is new, what oil temperatures should I start to pull back snd go slow when on the track?
I was planning on slowing down whenever I see anything over 280
For reference I have Amsoil 5W-30
BigBird
oil temps are calculated and changing from the stock 0W-20 changes the calculations even further.
I believe the actual temps once warmed up are about 20 degrees lower than it says on the dash from those that have use an actual sensor.
siwelnosaj
Jason
Reno, NV
Type R
When the oil temps go up so too will the water temps. For me I'm using 240 water as my upper limit. I'm going to adjust the settings so this read out turns yellow at 230 as a warning to myself I'm getting close.
keller
Somewhere south
2019 fc3, 2021 fk8
I ran time attack in 95F tuned and no over heating. Yes with no intercooler the IATs spike, but never limp mode, except when I was low on fuel.
Tezza says the same thing about his car, it's indeed curious. What water temps are you seeing?
When the oil temps go up so to will the water temps. For me I'm using 240 water as my upper limit. I'm going to adjust the settings so this read out turns yellow at 230 as a warning to myself I'm getting close.
So does the water temp reading give you a more accurate picture of whats going on than the oil temperature?
Tougefl5
Why not just get a oil temp gage instead of going by the water temp. I don't think it's that accurate anyway lol
siwelnosaj
Jason
Reno, NV
Type R
That's a fair question. I guess I would just say I'm more worried if coolant gets too hot for the sake of the head and head gasket.
If the oil were to be in the very high 200s or get over 300 that would be a sign to me to pull off, but I suspect the coolant would very likely also be past the threshold I want at that point
