Ktrw
- First Name
- Zach
- Joined
- Mar 25, 2024
- Threads
- 0
- Messages
- 132
- Reaction score
- 206
- Location
- United States
- Vehicle(s)
- 2025 Integra Type S
As @Club Version said, the oil temperature is a correlation/calculation which has been shown to be off by a bit versus a real oil temperature sensor placed in the oil pan (reads like 20F high in some cases iirc, but this is not a rule of thumb). Keeping track of coolant temperatures is probably a better way to gauge risk, and Jason (WOT) said around 240F coolant temp is the upper limit. Obviously lower than that is ideal, probably around 220F, but tracking the car on warm/hot days is going to push it up.I'm hoping to get some advice on oil for time trials/track days. I am having a problem with high oil temperatures (275) on mild weather days (70), particularly at Laguna Seca, in my 2025 FL5 running a totally stock drivetrain with stock 0/20W oil.
I installed the WOT plate and removed the rain guard but it didn't seem to help. I can't really afford to buy the aftermarket radiator and oil cooler(s?), but I really can't afford to prematurely ruin an engine.
Will a good quality 5/30W oil reduce the risk of engine damage, or do I really need to bite the bullet and spend the $$$$?
I'm heading to Laguna Seca this Saturday April 4 and hope to meet some of you there. Thank you in advance for your help.
Running 5W-30 oil is not going to help your oil temperatures, they actually would be slightly worse due to the higher viscosity, but would likely improve oil pressure. Oil pressure stability is an important aspect to keeping an engine alive in high stress environments, so it is worth looking into. The IMSA Civic Type R TCR race car runs 0W-40, so there is precedence from Honda to run higher viscosity oils in racing environments.
You do need an upgraded radiator and oil coolers to manage on track temperatures in these cars, though plenty of folks do it without them and seemingly don't blow engines left and right. Not saying it's right or wrong, just an observation.
