Not really! Remember if you have a oil the first number either 0W or 5W or whatever you choose is how well it flows in colder temps. If you live in a colder climate then lower numbers will help you since the oil will flow better and more quickly at those cold temps. Heavier oils will be thicker and not flow as well so you might not have the best lubrication on initial startup up if its freezing.Any issues if you were to use 5W-30 year round?
Where I’m at its so hot that 5w or 10W will flow very well since its always hot here in FL. When the cold temp of the oil will be in the 80F degrees just sitting. So just use the right one for where you live. If it snows and its freezing and you actually drive the car in winter then 0W is great.
